Relpacing starter clutch
  • Burnzi
    Burnzi
    Do you just replace the Starter clutch (31663-90) what about the output shaft (31664-94) does it come as a kit (that would make sense) with both pieces or do I need to oder the shaft seperately?
  • Burnzi
    Burnzi
    That would be replacing not relpacing for the heading.
    If its buggered then it will be the Starter Clutch not the shaft that needs replacing. Why are you looking at a new shaft?
  • Burnzi
    Burnzi
    Just thought it looked worn till I saw pics of one and yes it does look "ok". Didnt know whether they were both replaced or just the starter clutch.
  • Burnzi
    Burnzi
    Damn, good advice mate, the young fella had already ordered one on ebay, $68.00 I think. I didnt even think of the fact it might be the same as a car part.
  • Burnzi
    Burnzi
    All fixed thanx guys
    No ploblesm Burnzu, teh gyus illw elph you anytiem Relpacing yuor tsarter clulcth geer. Ha ah ha. notn enuff beeerz hey Bunzi?
