Front Wheel
  • Sparra
    Sparra
    I have a 1995 Softail that I put a 19" front wheel on and I think it improved it heaps...I aslo have a 2010 Wideglide that I would like to put the same front wheel onto...Does anyone know off hand if it would fit straight in with a bearing change...It's pretty hard to get an accurate measurement with out taking both wheels off and trying them...
    Cheers...Sparra
  • Will67
    Will67
     gday  sparra im not sure about your aplication but i just fitted a dna fat spoked 21'' to my softail standard i had mixed convisations with different people if it would bolt straight on some saidit would others saidit would not.
    well ihad to change bearings to 1inch hadto change  axle spacers and also had to make up spacers for the brake calliper.
    but totally different bike.
  • the_mongrel
    the_mongrel
    Similar to above, I put a 19 on my Fatboy from a 17, and also swapped the rear from 17 to 18 - completely different bike, and but fuck I love it! :)
    Keep us posted mate.
