cam bearing O ring
  • taff60
    taff60
     Hi, just replacing my cam tensioners and bearings on my TC88
    The rear Outer bearing came as a kit with bearing, shim inner and a little O ring. All is clear but can see where the O ring goes in relation to the cam.
    even the manual doesnt mention it. cant see where it fits and its holding me up. Any ideas? Sorry i dont have pictures.
    By the way, its a 04 carby and it had the crappy inner cam bearings made by INA. Now has torringtons.
    Tensioners were less than 20% worn. at 54k km's. prob didnt need changing, but got done because i had already stripped it down. Adjustable rods made the job easier
  • ozymax
    ozymax
    I know stuff all but is it for the oil pump?
  • taff60
    taff60
    Thanks hoodeng. Thats what i figured, just needed confirmation. And there wasnt one on the old one.
