Online: Soapbox2627
Vance and Hines for my 2009 NRS
  • LeMMinG
    LeMMinG
    Afternoon all,
    Ok so I've just got my 2009 Night Rod and I'm looking to put a Vance and Hines comp series 2into1 on it, being doing lots of research and decided that V&H is for me, but now I'm stuck at which one is the correct for my model/year bike?!?
    There is the VH Product ID : 75-113-9 which states it fits: 2002-2013 V-ROD and looks like the newest version of the exhaust, and then there is the VH Product ID : 75-106-9 which is stated to fits: 2002-2011 VRSC, but in the product description it makes special mention of "A replica of the Destroyer Competition Series Exhaust, this new system is designed specifically for all V-Rod Models including 2009 models and the Night Rod Special".....
    So my question, is the 75-106-9 product the one I should be aiming for, or does the 75-113-9 fit my bike as well?  What model does everyone else have fitted to theirs?
    The 75-113-9 is available in matte black as well, which will suit my denim black very nicely, but I need to ensure it will fit first ;)
    Thanks!
  • hquick
    hquick
    If it's a replica of the Destroyer system....I don't think you're going to want it. No muffler....just 2-1 dump.
    You won't be able to ride it for long periods of time.
    If you want to save some $$$ check out 'Danmoto'. Their system is basically identical to the V&H 2-1 (round muffler instead of triangle) and it's about 1/4 the price of the V&H.
    Mine was $258.00 to my door in about 3 days.
  • LeMMinG
    LeMMinG
    Thanks for the info hquick, some more to think about now :p
    Do you happen to have some pics and perhaps a vid of the sound from the Danmoto on your bike? Off to google them now...
    EDIT: quick google search and found the dan-moto site, but it doesn't look like they sell VRSC model exhausts anymore <img src=" src="/DesktopModules/NTForums/themes/_default/emoticons/sad.gif" />
    Double EDIT:.... reading through the thread on 1130.com forums at the moment.  So did you have to specifically get in contact to get a vrod system?
  • LeMMinG
    LeMMinG
    Ok so I just read the whole thread over in the 1130cc forum, looks the goods on your Muscle and sounds quite nice too.
    My only concern is the direct bolt on to the Night Rod, which it looks like it shouldn't be a problem but I'll be getting the local Harley shop to install exhaust and tune for me, so modifications can't be part of the package, but they don't have stock of them at the moment anyway.
    Interesting read. I'm waiting to hear back from the V&H about the exact exhaust which will fit the Night Rod too, so after I get the responses I'll go back to the drawing board and look at which way I want to go.
    Still keen to hear from other who have the V&H fitted though ;)
  • Coxy
    Coxy
     G'day lemming
    Currently have 3x VRSC (2 are for sale )
    Here's a pic of the 2011 with V&H Comp 2-1
    if you want to hear what it sounds like I did a review of another product on my blog but it includes a (pretty crappy low res) video from my phone going up through a set of twisties on this bike - but if you turn the sound up and you've got decent speakers you might just be able to hear what they sound liek at (almost) full noise and in deceleration, up change etc.
    (I still get a boner listening to it ... but that's probably Too much info right... hahha)
    goo.gl/4Bwsc
    Coxy
  • LeMMinG
    LeMMinG
    Thanks Coxy, looks the goods and sounds sweet, I'm going to have a look at the Dan-moto first, see how that pans out ;)
  • toecutter0000
    toecutter0000
    Can I just add my bit to the discussion? I have a V&H on my 2009 and it looks and sounds great, only problem I have is it HOT on my right calf muscle!! The header system is to close to my leg and when (I am not aware) and I need to push the bike backwards it can touch my leg. Other than that it gets lots of good comments from all aspects....
