2007 softy wont start
  • Shagger
    Shagger
    replaced batteries in fobs and bike butall i get is blinker lights goin left to right as if alarm is engaged but alarm is not sounding
    have tryed disconnecting main fuse connecting battery and connecting fuse as to reset computor as advised
    have also tryed not having fobs near bike and trying to reset with code and last number of vin as advised
    no success
    confused!!
  • KiwiRob
    KiwiRob
    Sorry if it sounds like I'm trying to be smart, but check batteries are the right way around in fob, or turn them around. - Rob
    And check you have the RIGHT batteries. There are a few that will fit, but they supply insufficient power.
  • Shagger
    Shagger
    even still you would think the alarm would engage?
    fob batteries are 3v same as i took out!
    weird hey!!
  • Shagger
    Shagger
    thats what morg & wacker told me!
    i have done this before when fob batteris were flat
  • Shagger
    Shagger
    have tryed that!!
    not finding the manual does`t help though!!
    The batteries have a life span of around one year, people have known them to last 2-3 years, I change mine every 12 months.
    Play it safe every 12 months and you shouldn't have any FOB problems.
  • Shagger
    Shagger
    kool iil try that
  • Shagger
    Shagger
    kool ill try that
