New front Tyre
  • AJ56
    AJ56
     Well after 5 yrs and 43K give of take a 1K I had to get a new front tyre for my heritage...  $212.00 fitted Dunlop 402 from GC Cycles on Mn Nth rd Enfield.  I was pretty happy with the preice and if I get the same out this one will be even happier..
    Man!!!! thats gotta be a record from a front runner. 43000ks? I gotta ask.......do you use the front brake. my record is 22000ks when i had my valkyrie. Sounds like you got a bargain on the newy too. Well done.
  • Colstah
    Colstah
    Geez! I got a touch over 7k outa my first front tyre on a custom springer!! Never more than 10k....
    AJ56 what brand of tyre was your front that you got 43K out of?
  • chriso
    chriso
    43,fuck man are you wheelstanding everywhere? 20 to a front for me. two backs to every front
  • petebob
    petebob
    Usually get 15-17k out of each end on the streebob. Running factory Dunlops.
  • ozymax
    ozymax
    must be parked up on a stand to get that from a tyre. that has gotta be an all time record
  • Sturgis
    Sturgis
    About right! I get about 40 thou out of front. Done nearly 100 thou and on third front. Mind you I'm pretty light on the front brake!!
    Still have original pads!!
    Just saying.
  • Will67
    Will67
     fark i only get 8k out of my 21"
  • AJ56
    AJ56
    I rang HH in Adelaide and was quoted $265, fitted and balanced. Dunlop 402. GC Cycles on Main North Road at Enfield cost $212.Fitted and balanced. I took the wheel off myself so probably saved a bit there.
  • Colstah
    Colstah
    Dropped my rear off to HH Adelaide in October this year, Dunlop 402 fitted and balanced $209.05..... and $3.50 to get rid of the old tyre
  • FLSTC
    FLSTC
    im not even gunna comment on such a ridiculous amount of k's on a front ......
    ....... maybe i just did ........
    i wouldnt use a tyre on a bike that did that many k's .....
