Online: B0nes
Road King Seat
  • Belly
    Belly
    Has anybody upgraded the Seat on 2011 Road King Classic for long haul? If so where to purchase ?
  • scotti
    scotti
    If ya talkin exclusively "comfort for long haul" , $740 landed including raincovers , removable rider backrest and matching pillion backrest pad , shipped free , you would be struggling to find better for big fellas , may be a bit chunky but so is my arse , still a great fit and looks to be in proportion to the bike , the missus loves it , by memory it`s 3/4 inch lower than OEM , 17inch rider and 14inch pillion widths !
    Check out the Mustang site and youtube clips of their factory and process , the pan is a fibreglass covered 16 gauge steal base , moulded gel and foam , rivitted , leather covered seat , impressive and extensive range , great to deal with , best upgrade and money i ever spent and makes the bike a absolute pleasure tourer , deffinately makes the OEM seat look and feel real cheap and uncomfortable !
    Quack , that DG seat does look quite firm indeed and seemingly looks nut numbingly cramped up front too man ?
  • scotti
    scotti
    Mustang Super Touring Seat
  • Canetoad
    Canetoad
    Hi Belly,
    Not sure if this will help but it will give you another option as I "downgraded" my seat to a reach seat but added a sheepskin for a trip I just did to Perth from Melbourne return (8200klms) and both my wife and I found the sheepskin just fantastic. I just bought a black skin added some elastic and glued a blanket undrneath it cost me $10.....
