09 Springer Street bob
  • Maus
    Maus
     My finished 09 street bob. I machined, turned, welded and fabricated all the little fiddley bits including bars and guard brackets.
    It has all sorts of extras on it and in it. I give much thanks to my local panel shop painter, thanks John.
    100% ridden and enjoyed!!!
  • deceptive
    deceptive
    love that springer look would love to do that to mine
  • RockerStu
    RockerStu
    Awesome...good job !
    Have you got more of a side/front shot ?
    How does it handle ?
  • Maus
    Maus
    Rides very well, the Fournale shock helps dampen the ride perfectly. I made the brackets out of 6mm stainless steel and had them chromed, but I am still waiting for the Springer I made to come back from the chromers. I made it stronger, with better material as I found that the DNA Springer a little bit too flexible for my taste. Ride wise the DNA Springer is great, heaps better than a VPW Springer.
    Nice.
    I'd like to see it with some Drag style bars !
  • Maus
    Maus
    I put twin springer Hawg Halters calipers and springer Hawg Halter brackets on the front and made my own brackets to fit the front guard. Hawg Halter caliper and bracket on the rear.
  • thegent
    thegent
    Good job. They look awesome
  • coffee guru
    coffee guru
    nice colour!
  • Maus
    Maus
     The colour is called "AC Shelby Cobra blue".
    I'm not much of a ford fan.
