help with CPS error that doesn't seem to be
  • spunky_man
    spunky_man
    hi guys, i'm hopeing someone can help me. i got a 2005 injected wideglide and  on the side stand i can rev the shit out of it, but stand it up right ok to, just can't sitt on it. the error code that comes up is for the crank position sensor, but have fitted a new sensor and also tried the old E.C.U. as i had a thunder max fitted. made a test light for the for the wires between CPS and the ECU, but i moved wires and even sat on it and it didn't flicker or anything. is there any other thing that might make it though the same code?????
    thanks in advance
    baz
