Fatboy Exhaust Help
  • mato_h
    mato_h
    Hi guys i new to the froum heare
    but i need to fined out some info about the exhaust for my 07 Fatboy
    It is a stock 07 EFI Fatboy and i want to put a exhaust system on it but i need to konw if i run the stock air filter and just put the exhaust system on
    or will i have to remap the computer or install some thing like a power commander unit ???
    or can i run just a set of slip on's with out doing the computer ???
  • mato_h
    mato_h
    Thanks for the info guys.
    And gmeikle i searched and found the wright up you did sound very ipressive but i do have a question or two
    it may sound dumb but the exhaust valve you have wedgied open is that the one between the 2 pipes it looks to me like a balence valve of some kined
    and do you know where you can get the xied's from i looked at the nightrider web site but its not there any more ???
    and with the xied's are they just a pre set A/F ratio and correct me if iam wrog but from what i have seen it is realy just a new O2 sensor wire's
    again thaks for your help
    oh i forgot what size baffles are in the slip on's you currently have fitted to your bike
  • mato_h
    mato_h
    Thanks for the help and i now know what you mean about the valve it's so obvious now
    and with the air filter have you done any thing with the backig plate or cover to allow more air in ????
    and i was looking at the web site and loking at the digonstic tool looks good have you or any one you kow used it ???
  • mato_h
    mato_h
    and sorry about the spelling my keyboard is playing up
  • Brett
    Brett
    Welcome Mato . i'm running the fuel shot . Love it. easy as . runs great.
  • Big Joe
    Big Joe
    Mato no need to butcher the exhaust flap. All you need is an eliminator plug. Simply plug in and away you go. As far as your fuel is concerned check out the fuelshot on our website. www.bigjoechoppers.com.au
    Weve had great results with these. If you decided to change air cleaner at a later stage the program will allow for that too.
