Reg display
  • Sweetas
    Sweetas
     so if i remember right from 1st jan 2013 we no longer have to disply the rego? im in NSW.cheers
    must have missed that one, why dont you have to display the rego?
    We were yapping about this in may last year. for those who missed it here it is again. The search tab is a wonderfull thing.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=16&postid=451207&view=topic
  • scotti
    scotti
    Thought it was Victoria only ?
  • Nomada
    Nomada
    Don't show rego in SA. No big probs. They send the papers out 3 months out.
  • Superglide2012
    Superglide2012
    No longer required in NSW as the Police have those camera things that tell them if a car or bike is registered. I reckon they'll try the front number plate trick on the bikes again soon cause the police will have to be behind the bike to find out not like a car where they can get them either way.
    Im not sure though if you have to keep your rego label till the rego is renewed or not.
  • Devo
    Devo
    Dont need them because the cameras can do an instant rego check.
    basically they hope you forget as you have no reminder on your window and they then send you a fine. hello revenue raising at its laziest.
  • FLSTC
    FLSTC
    thats good to hear
  • 78gold
    78gold
    My understanding is that this applies for any vehicles under 4.5 Tonne (I think) from regsitration renewal date of 1st Jan 13. I got this off the Transport and Maritime site.
    From 1 January 2013, registration stickers will no longer be required for light vehicles up to 4.5 tonnes Gross Vehicle Mass (GVM). NSW Police use number plate recognition cameras to automatically detect if a vehicle is unregistered.
    This means from 1 January 2013, registration stickers can be removed from all light vehicles registered in NSW. While it is not an offence to keep displaying your registration sticker, it is no longer required.
    New stickers are no longer being generated and will not be sent with registration renewal notices. Removing labels for light vehicles simplifies the registration process, reduces red tape and will save time and money for the community and businesses.
    I re-registered my bike in december and asked the question then and was advised I needed to put my sticker on for a whole 9 days. lol
    Ride Safe
    Nigel
  • the_mongrel
    the_mongrel
    I havent had my sticker on for nearly 2 years!! LOL!!
  • Superglide2012
    Superglide2012
    "will save time and money for the community and business" How? I save 5 minutes putting it on. Business usually get the employee to put them on and they are getting paid any way so no dollars saved there. I believe it cost the NSW gubbermint less then $1.00 for each label which we pay for anyway. Are we getting a reduction in rego of $1.00? I doubt it.
  • TJU
    TJU
    Hey guys any one know what the rego label situation in good old Queensland is ... would love to do away with it but something tells me we will be the last to comply .
    Tim .
  • Boy Racer
    Boy Racer
    Having my daughter check on this in Qld for us guys.
  • shingles
    shingles
    yes well i av mine stuk 2 a metal plate i bort at hd shop i dont like them but found kood bolt 2 underside of swingarm on top of belt plastic housing did up tite then bent down so is legible on left side an cheked titeness of bolt put loktite on bolt first an of all da places 2 affix seems da less outa place brakety thing $30 hd shop stainless man said bolt were frame splits at front behind forks bolt hole dere but bin told bloks wind 2 cylindas so i look an find dis bes place out of way down low an can still b read wif out bein invaseive 2 form of bike features jus my 2 cents
  • Hooky
    Hooky
    My label was mostly covered in head bearing grease.
