air filter & cover for Bendix Zenith
  • numbers
    numbers
    hey guys - anyone got an air filter and cover for sale to suit a Bendix Zenith carby (on my 76 shovel)?
    I bought one that won't fit - it's for sale and i will arrange advert  - teardrop style - maybe off an S&S
  • numbers
    numbers
    Has anyone had any luck with one of these ebay filters on a bexdix carby?  Anyone got just a backing plate that they want to sell.
    The ebay filter looks very basic.   If the filter is crap then i could just use the backing plate if it fits
    S&S B are the same as well as 1976 to 1986 stock  Keihin if thats any help for the backing plate mounting & breather hole's
  • numbers
    numbers
    cheers - thanks for that
  • numbers
    numbers
    wots the cheese on ur arse all about?
     sorry mate i push the wrong button i must have been drinking again
  • numbers
    numbers
    no problem - i accidently went into the attachment from thutu and it looked like some sort of hacker's shit
    Anyway - still trying to get the shovel going - fucked up the wiring and got a short, found it and hopefully will fix it tomorrow. Should then be right to get rego (i hope) - for rego, we made up a cover for the open primary, put on smaller bars, took off the sissy bar, put on indicators, changed the tail light and tried to make it look less radical.
