Advice wanted - what to use to secure the bike for simple jobs
  • Marvin
    Marvin
    Looking for any advice on what people use to sit their bike upright to do simple maintenance - like an oil change where you might want the bike to sit straight.  Not looking at a bike lift as yet as I won't be doing that much, just want something that I can be confident holds the bike straignt up and secure.
    Cheers, Marvin
  • Nomada
    Nomada
    Just go for a bike llift and save yourself all the hassles.
    Only about $150 when on special. Their too bloody heavy to use anything else without risking damage.
    As mentioned above, bike lifts from Repco - should sell for around the $150. There's lots of threads on here about them. Good value for money.
  • Marvin
    Marvin
     Thanks, saw one at auto pro (WA) the other day for around that.  How do you keep the bike stable on them - looked to me like they could get bumped off?
    On the repco ones you can use straps to tie them on - they have points on the side where you can hook them on. I've used mine a few times without strapping them (mainly because the strap was in the way of what I was doing) and its sat there nicely. You really need to give it a good shove (presuming its sitting right) to get them off.
  • Marvin
    Marvin
     Ok thanks, will have a look.  Cheers
  • philthy
    philthy
    Back in the day Marvin, I used to use my helmet on my 84 softail. When the bike was on the sidestand, I'd push it sideways ,to the left, until the back wheel come off the ground,all the wieght on the sidestand,  then kick my helmet underneath the bike, lower bike onto helmet and back wheel stays off the ground.Or move helmet so front wheel stays off the ground. Ha! rough and ready ,but done the job. I've still got the helmet but I'd get busted if I wore it. Actually cost me $3 at the markets yrs ago. Looks like a prince charles polo helmet!!
  • Marvin
    Marvin
     Thanks Philthy will keep that one in mind!
  • Colstah
    Colstah
    Yeah, I'd go the lift, now that I've got one I'd never go back. Well worth the coin and really comes in handy for cleaning too, especially doing the wheels.
     ya can go one of these gadgets at $129, or.....
    or ya can go an even simpler one like this
    http://themotorcyclestand.com/images/SS1000F4x6.jpg
    But the repco ones and similar from supercheap auto can be had for 98 bucks when on special, and it hold my 420kg ultra up no probs and i never use straps. Had it for 5 years now and no dramas.
  • Marvin
    Marvin
     Cheers, waiting for a repco one to come in tomorrow.
