Brake Bkeeder nipple/screw
  • mick44
    mick44
     I went to both Brisy dealers to buy a couple of brake bleeder nipples, as rear one is slightly rounded, ect. Bought the newies and their not the same and dont fit. Took em back, right part no. Checked current on the floor bikes, some models use same bleeder screw as my o8 softail, so their still in use. Dealer said, Harley is aware of problem, Still no correct bleeder screws. WTF, ring, ring some more, ring again, still no answer or supply of correct bleeder screws. ( the 08 uses a squat screw that screws into the caliper recessed drilling) How can something so simple go on and on and not simply be solved, Too bad if you couldnt ride bike cause your waiting on a bleeder screw.  Sense of humour is being tested. Must be a 2013 thing.
  • ozymax
    ozymax
    maybe try a brake specialist shop
  • KELD
    KELD
    Earls Performance Products. Google em mate.
  • mick44
    mick44
     Thanks Keld, will do, The factory bleeders have a little gasket on em, Rang again the smornin, Hd aus is working real hard at being aware of problem so im told, What a lot of shit, Its not rocket science,
