Brake upgrade??
  • terroristone
    terroristone
    yes its been done, XR1200 front caliper and braided brake hose will be all you need. The caliper can be had from harley for $210
    T1
  • terroristone
    terroristone
    there are clearance issues with the iron and 19"+ spoked wheels, its easily fixed by filing some off the back of the caliper.... Its a very common upgrade and well worth it.
    T1
  • Bartikus
    Bartikus
    First thing I did was put braided lines on it, I went with P.M. Calipers over the xr1200 just cause I hate buying off the stealers
  • terroristone
    terroristone
    Pads come with the XR caliper
  • PK2
    PK2
    Best low cost mod you'll do. I had no clearance issues on my 2010 Iron
  • Sida
    Sida
    whats the total cost of this upgrade (caliper, cables and fitting) if anyone has done it in recent months? $210 for te caliper but how much for the rest? cheers.
  • blackout
    blackout
    would there be any clearance issues doing this to a forty eight sportster ? would the caliper clear the 16" spoked wheel ?
  • terroristone
    terroristone
    Sida, get your parts and I'll fit them for you.
    T1
  • Sida
    Sida
    awesome, have to get the ok from the boss first :)
  • terroristone
    terroristone
    I got mine from HH, the hd stuff is ADR approved, if there are issues (failure/accidents) you will have a company to fall on/ sue. Don't fuck around when it comes to brakes, spend a little more and have piece of mind.
    T1
  • Fa1c0n
    Fa1c0n
    Sorry to revive a dead thread, but does anyone have any links to a set of good brake calipers for a 2012 forty eight?
    PS wanted to sell me "Hawg Stoppers" 6 piston calipers for $500....
  • slapster
    slapster
    XR1200 caliper about $210
  • Fa1c0n
    Fa1c0n
    And the XR brake is going to be better than my XL brake?
    What is the difference?
  • slapster
    slapster
    Yes far better. The XR caliper is a beefier 4 piston setup.
    Take some time & do a search - all the info is there. It is a popular upgrade.
    Slap.
  • Fa1c0n
    Fa1c0n
    Jesus christ!
    I have brakes that work now!
    XR1200 caliper is the best thing I have done for my bike.
    Outrageous difference.
