Jockey Shift
  • numbers
    numbers
    hey guys - i am interested in any comments about fitting a suicide shift and jockey lever.  I have a 76 shovel - cheers, Numbers.
  • kickinon
    kickinon
    foot clutch ,,.rocker style,? or to suit forwards.. a gear change lever attatched to the ratchid lid or you have to make up some bracketry if you have a rotary box? their a bitch in traffic, but like anything you'll get use to it...
    there a bit hard too use if your riding drunk 2 up in traffic
  • numbers
    numbers
    Currently have a clutch handle and forward controls
    I'm guessing that i need to buy a kit off ebay so that i can attach a jockey lever onto transmission and replace the gear change foot-lever to a clutch-lever
    Until now i hadn't thought about making my own bracketry
    Cheers,
    Numbers
  • numbers
    numbers
    Thanks Kiwidave - please send pix it will help - and thanks for advice (will save me buying the wrong stuff)
    I still need to buy or fabricate whatever bits needed
    My shovel is a kicker, forward controls, and with open belt primary
    Cheers,
    Numbers
    02 Jan 2013 10:24 PM Quote ReplyAlert
    I have run a jockey shift with rocker clutch on my 1985 FXEF 4spd Evo for 10 years now.
    The rocker clutch on mine stays loose so effectively it is a suicide clutch.
    It looks WAY harder than it really is. You do need to try to get into neutral for every stop but eventually it becomes second nature. I have never had any issues, ridden in big city traffic, freeways, suburbia, Scottish Highlands, the lot. No dramas.
    I would never make the conversion if I lived in San Francisco or Rome though. Hills are a nightmare and the scenario to avoid is the uphill stop sign or give way followed by a left turn. Bit of a nightmare.
    If you need pix I have some. Got Fabricator Kevin jockey arm, old Pan rocker clutch, custom rod linkage.
    On a 76 it will be much easier to sort even with electric start primaries but you will need the 68-78 FLH police style clutch release arm for ease of setting up the rod linkage. Rod is the only way to go.
    Do it! ;-)
  • numbers
    numbers
    Cheers kiwidave - thanks for the help - that should get me sorted
