Online: HD17
What is this?
  • rider
    rider
    Is it plastic or metal Hilly ? , something to do with a tensioner/ slipper ?
    Chain Guide perhaps?
  • rider
    rider
    Strange one what ever it is Hilly,,,, and NO Mate, don't put it back in, it's surpluss to requirements !
  • rider
    rider
     I'm not gunna sleep till I find out what it is Hilly,,, what are the dimensions on the bit at top left of the pic ?
  • V2Evo96
    V2Evo96
    Machined finish on any of the pieces (we can't see the other side)? Are the pieces light or heavy? Plastic or metal? Magnetic?
  • Will67
    Will67
    looks like bits of blue metal they use to pave roads
  • AJ56
    AJ56
    Worrying thing is that there may be more at the bottom of the crank case. It looks like a cam locking tool used at assembly. I reckon the idiot on the line dropped it and didn't bother to retrieve as it would have stopped the line.
  • wayne.craft
    wayne.craft
    I think you are on the money there AJ56,
    looks like an assembly lock that should have been removed...
  • clubbie
    clubbie
    Im with AJ. If it was metal tear it down asap. But when you said plastic I thought cam locking tool straight away.
    Looks like just the front bit that fits between the gears as the rest of the block is usually fairly large. Probably find some more bits in the filter and tank. Worth the time to inspect and clean.
  • AJ56
    AJ56
    Could be one of the teeth from the tool, but they are flat not rounded as Hilly has suggested. I still think something during assembly on the Engine line. If you have a look at the Utube Video of the assembly line they don't have a lot of time... And if something does go wrong then it just gets missed as is the case here. The pers on the line have bugger all time and it may have been a Monday Morning after a big weekend on the Moonshine.....LOL
  • paulsails01
    paulsails01
    This post may be a bit late but guesstimating these objects look very similar to a hardened and obviously fatigued oil seal, the bakerlite observation alerted me.
    The only place that I can think of were these findings might come from is the outside oil seal between the left hand crankcase and primary inner case. I dont have the knowledge or experience to comment on this further but, I am not sure if operational use would alert you to chenoballed primary oil seal, maybe check the primary oil level.
    Some of the older ,read much more experienced members ie evo, could possibly offer assistance.
    Just a thought for a guy who has helped many others.
    Paul
  • the_mongrel
    the_mongrel
    Man, that is weird!!
    I doubt if its the locking too. There is now way you could have closed it up with the tool still attached.
    Mate, I feel for you - It's going to wig you out every time you start the frigging thing.
  • rider
    rider
    Just had another thought hilly, could it have been a sealant or jointing compound that has been applied in excess and run down to the bottom of a housing before it set hard ?
  • oneball
    oneball
    Hi all...Thank fuck it aint metal.Whats to say it never came out of your new oil bottle from an oil change???
  • Stewy
    Stewy
    Could it be from the outside and somehow ended up in the cover before you replaced it last time.
    Mabey something that was laying around the workshop
