200 Rear on a 2011 FLSTN
  • rodrocket
    rodrocket
    greetings all
    long time reader hear & first time poster
    i am looking to fit a 200 rear onto my 2011 FLSTN delux
    can this be done with the standard Swing Arm or will i need to use a swing arm from a Fat Boy
    i am also interested in fitting a bob tail rear guard
    thanks in advance
    regards
    Rod
  • KiwiRob
    KiwiRob
    You looking @ a magwheel or spokes? The reason I ask is that I'm gathering the bits to lace an '09 RK classic profile rim to the Deluxe hub. The RK rim is 5'' wide which should take 200 tyre easily. I'm looking @ the180 WW.
    Your lucky as your frame is the later model version, where the fender supports are bolted on to the frame, where my '07 supports are part of the frame, so a wider mud guard can be fitted by possibly using Fat-Boy fender supports. - Rob
  • rodrocket
    rodrocket
    thanks for the reply Rob, much appreciated
    i am thinking spoke wheel & also a bob tail rear guard
    regards
    Rod
  • KiwiRob
    KiwiRob
    Let us know how things turn out Rod. BTW I think you'll find that your bike may have the same swing arm as the Fat Boy.- Rob
