Cobra PowrPro
  • hotcurrie2
    hotcurrie2
    Pete here,  I have just had a set of s/e slipons fitted to my 2012 sportster 1200 custom- it sure doesn't sound like a sewing machine anymore. my next step is to fit better air intake and a fuel management unit. I was wondering if anyone has any info on the Cobra PowrPro unit and its suitability for my 1200 sporty also where I can purchase one in Sydney, or,  is there a better alternative (I simply want to plug in and go- I don't want to muck around with settings etc). I'm not tech savy and I need to keep it simple, also don't want to get ripped of by any dealer for fitting charges.
    I really would appreciate any feed back.
    Pete(hotcurrie2)
    Buying from overseas is usually cheaper, but warranty is a pain of course. The only other thing I can say is I haven't heard anyone complaining who actually owns one. The only people who do are people who like to fiddle and shouldn't be looking at them anyway.
  • Sooki
    Sooki
    I have one
    Got it from M&M
    Works great plug it in and forget it.
  • hotcurrie2
    hotcurrie2
    Hi Sooki,
         Thanks for your reply, regarding Cobra SuprPro- How much did it cost you and how long did it take to get to you???
      Has anyone  in Australia used the SuprPro on a 2011/2012 sporty custom-if so was it succesful?????
    Saw your comments re- Sportster not being a mans bike-not a girls bike -something inbetween. I sort of agree, but this is my first big step up from small jap crap- I gues I'll keep it for a couple years and then get something bigger (a mans bike, as you put it).
    Regards
          Hotcurrie2
  • rider
    rider
    Like most things Pete, it's not the size that counts,,, it's the way ya use it Mate.
    Cheers, all the best.
