Online: Soapbox2627, B0nes
Hard starting
  • oneball
    oneball
    Hi all...camy18,Sounds like the pilot jet is to lean.
    clean fuel tank out 1st then carb blow clean all jet passage's , idle jet should be  45, main jet  around 180  depends what exh system  for main jet , fuel bowl level should be 3/4 to 7/8 full bike in upright possie ,  mixture screw 3 full turns out ,                best too check timing as well  with a timing light  while your there
