Online: John.R, speedzter
RSD Vintage apes vs Road 6 Custom
  • Naych
    Naych
     Got to size up the 10" Road 6 Custom mini apes on a 48. So comfortable I wanna put them on my Iron. Anyone compared these with RSD Vintage apes? The RSDs look like the grips are wider and lower. You generally get what you pay for, so I suspect the RSDs are better quality.
    Appreciate anyone's opinion/experience.
  • terroristone
    terroristone
    i have 2 sets of road6customs, great bars and well built, welds look to be good also, from what i can find out they are both chrome molly so they are going to be as strong as they can be.
    T1
  • slapster
    slapster
    ^ that first pic is awesome. What effect/filter did you use?
    Slap.
  • wildkatze69
    wildkatze69
    slapster, try an app called snapseed. either for iphone, android or desktop. play around a bit with it and you'll get awesome photo results that are beyond the ones from instagram.
  • Naych
    Naych
    Nice shots China, both I'd 'em.
    So if the quality is good for both and I know I like the Road6Custom shape, should stick with R6C and save a few $$ for other mods. Is there a supplier in Aus or does everyone go eBay?
    And Merry Christmas everyone. :)
  • nhb006
    nhb006
    Ive got a set of 10" road 6 apes at home you can have for $80... They came off my old Iron.
  • Naych
    Naych
    I've just ordered the 12" with cable kit, otherwise I would have taken you up on the offer.
