Online: Soapbox2627, B0nes
Forward Controls for 2013 super low
  • leesa069
    leesa069
    Just wondering where the best place is to purchase a set of forward controls for the 2013 super low, Bit pricey in Adelaide so thought i may as well shop around see if there are any better prices :)
    Cheers for ya input
  • terroristone
    terroristone
     use genuine HD ones mate. All the aftermarket ones are junk, i had a set of the "cheapies" that broke on me, i have had the broken parts replaced.  The same day i went and got new HD ones and pulled that shit off my bike. Not worth dropping your bike over a few $.
    Have a look in the Wanted to Buy section and ask Sam for a deal.
    T1
  • JOHNO23
    JOHNO23
     I agree with T1, I had my forward controls for my iron done with genuine parts for the same reason.
    not worth getting stranded out on the open road with broken gear, just to save a few bucks,
    mine have been spot on since day 1.
    Johno.
  • mato_h
    mato_h
    You cal always check out VPW they can can do some pretty good prices
  • leesa069
    leesa069
    Will do thanks :)
  • terroristone
    terroristone
    Mato, if you want the vpw set you can have mine for cheap....
    T1
