Online: Soapbox2627, B0nes
Inverted front end
  • 86fxr
    86fxr
     Can anyone tell me if an inverted xr1200 twin disc front end would fit up to a 1986 fxr frame , and would the rake degree and length be similar to an original fxr front end ? Thanks.
  • Paulie73
    Paulie73
     You be best checking harley part numbers s they keep using the same triples etc for a range of years and models. If they match up they fit. Sorry cant be more help but you never know what people know on his site.
  • 86fxr
    86fxr
    Thanks for your reply that gives me somewhere to start cheers.
    Subscribed.... Same bike and same theory here!
  • 86fxr
    86fxr
     I like your turbo setup,were you having trouble with the front end prior to your steering damper?
    would you know anywhere that I could buy a gearbox ,inner and outer primary clutch and compensating sprocket to suit 86 fxr? Thanks.
     all harleys have a 1'' dia steering shaft from about  sporties from 1982 & big twin s from 1960 the sporty shaft  is a bit shorter than the big twin but i have used a spacer under the bottom bearing too fill up the difference  but best check on the XR dia
  • 86fxr
    86fxr
     Thanks I'll check
    Re my fron tend...Yes the bike would get a wobble on fast sweepers (at about 100-120kph). Once the damper was fitted i can do the same sweeper at 160+ (not that I would ever try that...lol).
    Just added a fork brace this week and man what a difference it makes. the entire fron end is now really tight and dead on! just need to get the suspension done now and I'm good to go.
