Online: Soapbox2627, B0nes
Installed a new battery and now it won't start efi sportster
  • wristtwister
    wristtwister
     Hi Guys, I've got a 883 08 sporty efi with a Fuelpak. A few weeks back I help a mate out and took my battery out to take off the trickle charger leads to charge my mates battery, my bike sat for a week and when i re-installed and the battery it  was flat and wouldnt start. I tryed recharging the battery, reinstalled it and the efi pumped fuel and when i pushed the start button it clicked but would not start. I went out and bought a new battery, charged it overnight installed it with trickle charger leads then without , it has plenty of charge, fuel pump works and pumps fuel but it has no response when I try to press the start. Also the lights and horn works well and the blinkers flash left, right left right? Anyone had this problem or am i doing something wrong? Any help would be great cheers Graham
  • wristtwister
    wristtwister
    Sorry posted twice!! I could say silly iPad but it probably silly me! Haven't posted here for a while. Cheers G
  • rider
    rider
    Not tryin to be smart, but it ain't in gear is it ?
    That being OK, the next thing to check is for loose lead/s
    Starter reley, starter solenoid.
  • Nomada
    Nomada
    I read a post ages ago about a bike that didn't start.
    It was in neutral because he pushed it, but because the neutral dash light wasn't on, the bike didn't start.
    Doesn't sound like a battery issue.
    Do some Harleys have the bike stand doohicky that wont let the bike start when its down? If so, maybe the stand sesor thingy is faulty, or the stands down?
  • mato_h
    mato_h
    make sure everything is connected correctly (no loose wires)
    clicking sounds like a flat battery problem also check any fuses perhaps one has blown with all the swapping and changing. but if you can get your hands on a mullty meter check the currund draw when trying to start. may be a starter relay problem ? worth a try
  • wristtwister
    wristtwister
    Thanks for the reply's... Bike definitly in neutral with dash lights aswell, stand is down. I will check all connections, fuses and borrow a multimeter etc. cheers G
  • JOHNO23
    JOHNO23
     You may need to do something with the security code mate,
    this is done via the back button on the speedo housing.
    you may need to punch in your security code to reset the system and disable the cut off mech.
    its a long shot but it may be the case.
    Johno.
  • als1200
    als1200
    sounds like a wire left off for the relay? or fuse.  no sorry just re read your post.....you got a click from the starter.  that means the switching is ok.... check battery leads are tight and clean (very important).  put bike in gear and rock it backwards and forwards (incase  drive is stuck forward).  might help.
  • wristtwister
    wristtwister
    It was the Fob Battery! Thank You very much guys. Its great to know you can get plenty of help from the forum. Ill have to poke around on here more often. Thanks again and have a Merry Christmas...im going for a ride...Cheers Graham
  • Nomada
    Nomada
    Glad it was a cheap fix -
    or did you get a genuine HD FOB battery from the stealers...........lol
  • mato_h
    mato_h
    "Fob Battery"
    wow that's good you sorted it out but i wonder why was the alarm not sounding when you tried to start it ???
  • freebeer
    freebeer
     Flat Fob batteries tend to catch out people all the time. HD recommends you change the batteries every 12 months and remember to use the correct battery in your fob too. There are some that will fit but arent the right voltage which will cause your fob to do all sorts of funky shit to your bike.
    Good idea to remember and practice using your pin because as Murphys law suggests the time your battery does go flat is going to be the most inconvenient possible time like when you are crossing the nullabor or something like that.
