Online: HD17
204s in stock 103
     i depend's how many part's they are going too replace , when i do a job i replace the cams + 4 cam follower's ,  2 timing chains + 2 cam chain adjusters shoe's  + gasket's  & i go in thru the top of the engine & use the stock pushrods , not go in thru the side & cut out the pushrods & fix those ezi install pushrods  thats the lazy way
  • Spero
    Spero
     Fattywa, if you put the 204's in I'd be real keen to hear what you think of them..
  • nhb006
    nhb006
    Ive got em in my 103 with 1.725:1 rockers. Goes well!
  • Geoff3DMN
    Geoff3DMN
    I looked at the 204's for my 103 but ended up going with the 254E cams instead because I was staying with stock compression and rockers.
  • Geoff3DMN
    Geoff3DMN
    Baloff I am happy with the 254E cams but I don't really have anything to compare them with other than stock (on my bike) and 255 cams (on another bike). They definitely give the bike more grunt for what that's worth.
