Online: FONTANA302
Moto Hooligan airbox
  • dav466
    dav466
    HI I have completed dyno with se tuner on my VRSCSE and topless airbox love the induction sound but hate the valve noise, sounds like piston slap in my old XR 500 from years back.
    I just come across the Moto Hooligan airbox and asking if anybody out ther fitted one?
    Does it have the same noisey valve sound as topless setup?
    Looks great and dont want to shell out $ if has the same noisey valve sounds.
    Cheers Dave
  • ralphski
    ralphski
    Can you put up dyno results, always good to see what other results are.
    Motohooligan, alot of $$$, for little results???????
    valve noise? Maybe i can't hear that because of pipes.
  • tubz
    tubz
     I had a good result out of my moto air box on the dyno.
    there is a little valve noise but you really can't hear it over the engine.
    all in all I could not be happier with mine and think its worth the cash.
  • 2012vrod
    2012vrod
    The motohooligan website says 3-5 extra horses without tuning. you guys reckon it would provide much more than a replacement K&N filter?? I'm referring to the removal of the internal airbox and replacing it with the new filter.
