Online: FONTANA302
New Wheel
  • Sparra
    Sparra
    I am wanting to put a wider front wheel on my 2010 WideGlide...I don't want anything fancy,the same as what is on there is fine as long as it's wider than stock...I have checked with Walka and he has none at the moment...
    Anyone have any ideas what will bolt straight in??? I went down the new rim and lace to existing hub with my WideGlide and now just want something that's a straight bolt in,either 21" or 19" for the WideGlide...
    Cheers...Sparra
     you could have a wider  front rim relaced  in 21" with one of the 120 /80 / 21" tyre's, try not to buy any of that cheap shit that a lot of outlets push it's all crap  buy good or better than harley original or you just de-value your bike while the junk seller get's rich
