Online: FONTANA302
Roland Sands Headlight Relocation Cafe Style
  • mikedsilva
    mikedsilva
     Looking at one of these... but not sure if I can get away with just buying the bracket without the LED lights.
    If I buy just the bracket,will my stock lights work with it? Has anyone else had experience?
    I'm assuming that it must work with the stock lights, otherwise they wouldnt give an option for buying the LEDS.
    Then again, why buy the LEDS over the stock lights? Just brighter?
    http://www.rolandsands.com/products/Gauge-And-Headlight-Re-Locator-Black-Anodize
    But I notice they also sell the LED lights separately...
  • slapster
    slapster
    There are independent connections for the speedo & idiot lights. The RSD LED's are just for convenience but need wiring up. Assuming you buy the RSD bracket how are you looking at mounting your idiot lights? and what will you use for a top clamp?
    I'm ordering the RSD bracket shortly & gonna try it with my Joker idiot light bar clamp (the stock idiot light bar screws up underneath the clamp). My only concern is the clamp obscuring some of the view (my new gauge has the digital speed in the lower RH corner of the dial) but if it does I'll resell & try something else. The other option is buying the RSD LED's add $50-$60 plus the RSD risers (for better view) add $150ish, my RSD/Joker solution is cheaper just hope it works & looks ok.
    Slap.
  • MBF
    MBF
    Hey slap
    I did the rsd relocation with the jm handlebar clamp with idiot lights and I can't see the bottom 1/3 of the speedo. Will be taking the handlebar clamp back off and go with the rsd led's.
  • mikedsilva
    mikedsilva
    I was sent a message by a store owner who said I can use the stock lights on the new RSD relocation bracket.. I have taken anything apart yet, so I'm not sure if that is feasible... sounds like I really should order the braket and LED lights at the same time...
  • mikedsilva
    mikedsilva
     So where is the best place to buy the bracket with the LEDS?
    ebay?
  • SJ
    SJ
     I have this headlight relocater, and the RSD led's, but haven't gotten around to putting the leds in...... can see the speedo fine, but I would need separate bar clamps or clamp on bars to see the led's clearly.
    Figured I have dealt without it for over a year, no rush. But cheers for the reminder!
    SJ
    Here is some pics if it helps:
    hdforums.com.au/Default.aspx
  • slapster
    slapster
    Thanks for the thread link SJ, thats some handy info & pics.
    Slap.
