Online: Soapbox2627, Hilly, evo94
Rear pulley size recommendations for highway cruising
  • 06 Softail
    06 Softail
     Hi there, I was interested in trying to reduce engine rpm during highway cruising. I feel that when cruising at 100 km/h or more on my Softail, it really could do with an extra gear to stop the engine from screaming it's tits off. Unfortunately it's only a 5speed, so I thought by going to a smaller pulley, it would be better on the open road. Any suggestions for a suitable size pulley which would be ideal for both town and highway use without compromising engine performance? Cheers.
    P.s I think the current pulley is the original one from factory, not sure on tooth size though, might have to see if there is tooth size cast into the pulley somewhere.?R
  • ozymax
    ozymax
    reducing the tooth count will help but you will be limited by the current belt length. I think the tooth count is on the inside of the pulley
