efi info
  • windsorsmith
    windsorsmith
    G'day.
    I need help please. I've just bought my first efi bike, a 2005 softail with factory pipes & air filter, I need more noise & power. This has probably been covereed in the past,can anyone point me in the right direction?
    I have always done all my own work on bikes & cars & I have a well equipped workshop, mechanical & electrical,but I need some guidance.
    Thanks in advance.
    Smithy.
  • the_mongrel
    the_mongrel
    Hey Smithy,
    Heaps of info here man, and yes - the first point of call is air and pipes - BUT - You will need a tuner, or you will be WAY out of tune and very lean!!
    Have a read through the workshop and EFI sections - Heaps of info.
    Mongrel
  • windsorsmith
    windsorsmith
    Thanks mongral, that's what I thought I will have to get a tuner, but I don't know anything about them. I will just have to spend the time reading as you sugest.
    Smithy
  • KiwiRob
    KiwiRob
    First off, you have an early Twin Cam without 02 sensors so XiEd from Night Rider maybe the go for you if you’re intending to up-grade to just slip-ons/pipes & AC.
    If you’re adding cams & head work also, then you will need a dyno tune with the dyno operator’s preferred tuner.
    If you would like to tune the bike yourself, then, by adding 02 sensor bungs & sensors to your exhaust pipes, along with a few other bits & pieces, you can use TTS, Powervision or the Screamin Eagle Race Tuner systems. They do require a bit of effort @ first, but become easier the more you get into it. - Rob
  • HogBag
    HogBag
    Smithy
    Chose your tuner carefully because some give 100% back up some give 0% back up. Most engine builders are running the same EFI tuner and are willing to give great advice if you decide to build a modified engine at home and you are willing to tune your own.
  • windsorsmith
    windsorsmith
    G,day KiwiRob.  First plan is pipes & air cleaner, don't what after that .I would like to add 02 sensors to keep an eye on afr, I did'nt know this bike did'nt have them, I thought all modern efi had them. my ignorance ha ha. I have always done my own engine work & tuning , would like to continue, I will learn slowly. Has anyone had experience with Daytona products, they seem to offer what I need at a reasonable price, maybe I'm wrong?  Thanks for the help.
    Smithy.
