Online: Soapbox2627, evo94
Scavenger - Oil Change System
  • bliz wiz
    bliz wiz
    Well I have just finished doing an oil change using the Scavenger System. Boy what a F@#$%^ around but I have done 20 klms and instead of a streaky dark oil on the dip stick the oil is clear.
    I am giving the system the thumbs up. Hopfully I will be able to do changes a bit quicker with less mess!
    It only took a couple of weeks to ship from USA. Have a look at http://www.rouguechopper.com
    Wiz
  • The Ox
    The Ox
    I've got a scavenger too.First time I used it  the transparent hose came off the oil return line,what a fucking mess it made, but I have to admit it does flush alot off dirty oil out.
  • Ando
    Ando
    made me own outa old filter, every oil change use about 4 litres but happy knowing have all fresh oil in my sled
  • the_mongrel
    the_mongrel
    Yep! 2000ks in and my oil is still hard to see on the dip stick!
  • sic-puppy
    sic-puppy
    so how does it work?
    i had a look at the site but could not get the vid to work
  • the_mongrel
    the_mongrel
    It works by basically pushing the old oil out of the system. You hook it all up and kick the bike over and let it idle, which uses new oil to push old oil out. :)
  • Superglide2012
    Superglide2012
    http://www.roguechopper.com/ will work. You misspelt the web address.
