Online: GGUser744
upgrade evo suspension
  • Jinx
    Jinx
    hoping someone might be able to give me some advice on a suspension upgrade. I have a 94 heritage and on corners that have the slightest bump it starts to bounce around all over the shop. I know there are plenty of aftermarket stuff but i don't know what ones are good. (Front and rear) Also what grade of oil is best for the forks ? Cheers
    progessive 422 rear shocks  , 20w oil in front ultima forks is what i use
     i put Bel -ray 30 w  fork oil  with a air cap conversion i do , next step is gold valve's & race tech springs .  stick with the stock forks no problem's
    Steering dampener took ALL the wobbles out of the FXR...can do sweepers at 160+ without an issue.
