batterys
    yep had 3 ssb of the guy from fleabay all shit just out of warranty when the first one shit i replaced the stator an reg as thay where charging slightley high
    next battery agian just out of warranty , got a a oem from harley been in it for 18mths has done no work mostley storage put a tender on it every now and than started my new build last week put the tender on for 2 days all good battery as good as the day i got it the other one was in my boys mini chopper it shit two right on warranty tender every few mths two oem for me now on and thay are apprantley made by deka ?
  • Geoff3DMN
    Geoff3DMN
    Yup I had a yellow motobatt shit itself in way too short a time... not touching one again.
    Interesting. I'm using a Motobatt in my 950 KTM, and it's been in for about 12 months and still cranks well.
    They run at 11.5 comp' @ over 200psi cranking.
    Thought they might be a good option for the HD when the time came. Maybe not from the sound of it !
  • scotti
    scotti
    My oem battery is just fading now after 3 1/2 years !
  • taff60
    taff60
    A genuine battery for my fxd was quoted at $180 ish. Didnt need it in the end as my battery optimiser recovered the orrginal battery. My fault for leaving the parking light on for5 day when i was away. The funny thing is, It is THE original battery and my bike is 04. When it finally gives up the will to live, Im buying genuine!
  • wazdog
    wazdog
    Deka for sure. Nothing better. 6 years and still cranking strong on a 10.5 comp (205 psi) motor.
  • Spinner
    Spinner
     Just replaced my odyssey pc545 battery which was having trouble starting my 107 build 215 psi compression when hot with a ssb 450 cca $150.00 unit like you are thinking about, this thing fires the bike up in a hart beat hot or cold so far so good good service and advise from the fella I delt with.
