Online: beaglebasher
Parade fan or air horn ?
  • Underground
    Underground
    Washington state? why not just mount an anti-tank gun or patriot missiles?
  • HogBag
    HogBag
    I would have both if stuck in stop-start traffic everyday.
    http://www.jagg.com/FP2400.html
  • scotti
    scotti
    Mate check this out , same fan designed to kool Nascar brakes !
    Can lower cylinder head temp by 100 degrees , thermostat or manual on/off switch , black or silver , also houses the stock fog horn , actually looks pretty trick too , fairly compact !
    Rollies Speed Shop are stockin them here in Oz , new L2R advert !
    JIMS ForceFlow Cylinder Head Cooler !
  • scotti
    scotti
    The JIMS one incorporates the both , fan and stock horn , behind the same mad looking fan/horn cover , sprucing up the left side a bit too , worth a look i reckon hey , conciderin one meself !
  • scotti
    scotti
    $380 - $420 AUD at JP Cycles or Rollies Speed Shop !
  • killerchef
    killerchef
    actually didnt realise that it got that hot in seattle. i thought it rained for a good 2/3rds of the year there. if that is the case, then you may use the fan a handful of times a year. the horn could come in handy a handful of times a week.
  • Canetoad
    Canetoad
    Hi Mates,
    I would suggest the airhorn is a priority for most riders, I fitted one and it has been a fantastic addition to my bike and stopped numerous idiots trying to move into my space eh!, as for the fan I would agree that it would be a good thing to run your bike cooler though I have fitted Xied's to my roadking and that has dropped the engine temp quite well though probabley not the same thing as a mechanical device though.
    Regards Len
