Online: GGUser260
Drag Bars
  • Superglide2012
    Superglide2012
    Do ya reckon drag bars would look good on a Super Glide Custom Dyna?
    What rise and reach do you reckon I would need?
  • Superglide2012
    Superglide2012
    I would need something leaning back towards me then. I dont need additional pressure on my back. Thanks Chopaweeza.
    I ran them with 5" pullback risers, and used Night train bars with a slight bend.
    Worked really well for throwing the bike around with mid mounts.
  • Colstah
    Colstah
    Drag bars look really good on springer softails (did I mention I have drag bars?).
    What I didn't account for, and which I still haven't fixed to this day, is that the standard risers with drag bars on my springer (94) means the throttle cables bite into the tank on right lock. Don't know if that will happen on your Dyna, but you might want to bear it in mind...
  • Superglide2012
    Superglide2012
    Tbars? never heard of them. Ill have to look. Thanks Chop and Colstah. Very interesting. I dont want to hit my tank.
    I put H-D 4" curved risers on to pull the stock bars back a bit . I,m 6'2" and it changed my arms holding the bars from straight elbow to slightly relaxed . Didn,t change any wires or cables , worked a treat for me .
    Your giving me Flashbacks Peg.............Not to mention the sore neck......
  • Superglide2012
    Superglide2012
    Thanks Peg for the pics. As for your avatar it did take me 30 minutes to actually notice the riser photos!
