Online: HD17
Headlight Wiring Diagram
  • MS3368
    MS3368
    By chance does anyone happen to have a headlight wiring diagram for a 2012 1200 XL Custom.
    Thanks in advance
    Mark S.
  • terroristone
    terroristone
    i have the lot but its going to be quite time consuming to put it all on here for you. be more specific on what you need and i might be able to help.
    T1
    Oh and change your avatar, its giving me an epileptic fit!
  • MS3368
    MS3368
     Mate, just need the diagram that shows th wiring connections between the headlight, handlebar switch and battery.
    cheers Mark
  • MS3368
    MS3368
    Or more simply, just need to know where each of the four wires coming out of the original headlight go?
    Cheers Mark
  • MS3368
    MS3368
    Thanks mate, you're a champion, just what I needed.
    I might even change my avatar, just for you.
    Cheers Mark S.
