Rotor knackered again
  • Burnzi
    Burnzi
    Just pulled the front pulley off (3" BDL) and the rotor has elongated on the splines again. Anyone know how to fix this?
  • houli
    houli
     Use bearing blue on one side of each mating surface, assemble, nip up, disassemble then check for point of contact, something may be bottoming out and not allowing full tension to be applied, the after market rotors are not as thick as genuine and may require a spacer, the contact points should be on the oil seal spacer to  spline boss on rotor to spline boss on pulley to nut, not the outside of the pulley to rotor. Hope this helps, I'm dealing with a collapsed lifter bearing on my old shovel.
  • Burnzi
    Burnzi
    Thanx mate on to it now. (amongst other tidy ups)
     in the aftermarket world they have a rotor with a wider spline  for the bigger engine's as this is the normal ,  is this & EVO style thin rotor ,    was she tight enough down there if you know what i mean,                                 + is the front pulley a good fit on the spline if thats worn it could be the cause as it move's about ,    no cush drive on a pri  belt  system or in the back wheel  have too do it up tight
