speedo/tach
  • Will67
    Will67
     hi fellas, i just ordered one of these, i forgot to ask the dealer but does anyone know when i replace this will the kmh that the bike has done stay the same or will it set back to zero once installed?
    are the k's recorded in the speedo unit or the ecm?
  • Aussie XB12SS
    Aussie XB12SS
    You transfer the km's at the start of installation.
    Kit comes with a transfer cable & instructions.
  • the_mongrel
    the_mongrel
    Depends on your bike. 2011 and up I think store the Kms in the ECM. My 2010 didn't so in know before 2010 you can start at zero if you want. :)
  • Crazy Erny
    Crazy Erny
    Hey Will, I have been led to believe that all the info is stored in your E.C.M which you probably know by now, where did you get the speedo from & how much did you pay for it? And can you post a picture with it turned off?
    Cheers mate have a good week!
  • Crazy Erny
    Crazy Erny
    Thanks Will, much appreciated, I like the first one you put up best, although I could live with any of them if I had to! Bahhaha.
    Cheers mate!
