Online: Retroman, GGUser744
Wego Users
  • carbon fibre
    carbon fibre
    Got ya message Hilly, cheers.
    Looks promising:)
  • Sparra
    Sparra
    Hey there Hilly...You think I could use this to fine tune my map???
  • Sparra
    Sparra
    Has anyone bought this yet???I did but can't seem to open it or copy/move it to the required folder...
  • Sparra
    Sparra
    Hey Hilly...I got it working with the licence...When I go to copy ve tables into it, it says too much data to fit...I'll keep playing...I also sent you a couple of files last week,did you get them???
    Cheers...Sparra
  • Sparra
    Sparra
    I managed to get the bits and pieces into this and did as they said...Put the map into my bike and went for a blat...It seems to run well with nice even power but it takes a few cranks to get started when it is hot, wasn't like that before...Comparing the ve tables to before and after there is a bit of difference but I'm still not sure how to read them...I'll run this for a week or so and then load my previous map and see if I can notice much difference...
    Cheers...Sparra
