Online: GGUser260
Cam Timing
  • DK40
    DK40
    For the experts.
    If you install cams and get them one tooth out, what is the best way to check?
    Will it show up in a compression test?
     comp test , could crash valves into pistons ,    i measure down the spark plug hole  too  against valve opening & closings every model is good but some sporties can be hard esp the time you get too cam # 4, but you have too move the crank foward in motion to see all the timing marks line up proper no just static
  • DK40
    DK40
    Was bugging me yesterday so pulled the cam chest.
    Checked cam dots 3 and 9 o'clock and timing marks OK.
    Need to check for an intake leak now. Will do that today.
