Online: beaglebasher
dyno results
  • dvstreetbob
    dvstreetbob
    Hi lads,
    i have just ordered a set of Cycle Shack slip on mufflers for my streetbob after leaning the hard way about straight shot full system from V&H. does anyone have Cycle Shack mufflers on a streetbob? i have SE stage 1 with a K&N filter, SE 254e cams, PCV and very soon the SC mufflers, 96 inch with stock heads.
    would love to know someones opinion on the sound, and how they perform. i am taking the bike straight up to be dyno tuned as soon as the mufflers are on, so it will be interesting to see the gain/loss in torque or HP over the V&H. (the v&h sound crap since i installed the cams). Has anyone got a similar setup and had it dynoed as i am interested to know what sort of torque and Hp i should be looking at getting.
  • shingles
    shingles
    exhausts r a personal thing i think that cycleshak is shit stuff sorry rush is the only way you should be going sound an go been there dun all dat shit ,the best way i found go on u tube type in  your bike an ad shack muffelers an you will most likely find wat u lookin for an hear them there will b sum shit posts u may av 2 play a few untill u get a vid done right but this is wat i do to listen 2 sound of pipes
  • DUNKSY
    DUNKSY
    hi dvs i have a set and i think there great like shingles says its a matter of personal choice but like i said mine sound great had no issues fitting and quality was good  and had no issues with cops because they have no logo on them i say they factory still lol gets em every time
    post up tthe Dyno results as we would be keen to see how she goes!
