Online: John.R, tussuck, Hilly
ACR's
  • DK40
    DK40
    Got the ACR,s wired in last night what a PITA behind the fuse box.
    Question is if I want to check my comp now how do you turn them off?
    Do you turn them off in the map and reflash?
    Cranked it over with the spark leads off to see if they are working, do the make a clicking sound?
    Sounds like they pulse on and off as it cranks.
    Anybody know
  • DK40
    DK40
    Had a play this arvo and removed the old fuel pump fuse.
    Did a comp check and it cranks at 125psi with the ACR's on and 180psi with them disconnected.
  • HogBag
    HogBag
    Sounds like there working fine.
