Online: beaglebasher
LH cover
  • als1200
    als1200
    Ive posted in the wanted area but this might bet ok. Ive lost a LH cover ( was chrome but I dont care)I lost one on a ride recently. I gave one to a forum member ages ago, never thinking I would need it. If anyone has one no longer needed give me a pm. If not the states is looking good. Thanks in advance- al
     i think i might have one of those later model lefty  bat cover's in black
  • als1200
    als1200
    It's an 06. Daddy if you have a black that would be great. Like the look of the early square style, but it aimt going to happen. Amy help is really appreciated.
    i will have a look tomorrow
  • scrivens
    scrivens
    I don't have a spare, but when you get a replacement, bore a couple of holes about 1/2" apart just near the front edge, loop a piece of solid copper insulated wire through the holes and twist tie the ends to the wiring loom near the frame. You can't see it if you use black wire (I used a length out of standard solid twin core house wiring flex) and it will stop it falling off. I nearly dropped mine once when I put my leg down at the first set of lights after a long country run and got the open cover snagged under my calf/knee. Wired it up as soon as I got home and 8000km later it hasn't come loose again. Only takes a second to untwist the wire and release it when you need the cover off.
  • slapster
    slapster
    Yeah I have a plastic zip-tie securing my LH cover in case the lug pops out.
    Slap.
    i have a black lefty side cover  07 model in good con'd  no worries   , are you in Rocky i will have too post it  you can have it  for 7 lottery ticket's ( lucky 7   if i win you can have 1/2  is that fair ,  but you pay for the postage , tie wire is the go i even tie the side covers on my early Z1 900 & Z1R 1000 as well  because they tend to blow off
  • als1200
    als1200
    cheers daddyracer56.. pm sent.
     parcel sent C.O.D.last thursday
  • als1200
    als1200
    Thanks buddy. Will lookout for it. Don't forget to pm me your address.
