Online: wildchild, John.R
Mikuni 42 slide rattle
  • reaver_05
    reaver_05
    I've just put an EV27 cam in my 99 softail EVO motor. Now at idle the slide in the Mikuni 42 is rattling.  I know it's the longer duration cam that is causing it to rattle more at idle and have read all the info on the problem from the Mikuni site, but they  have no fix for the problem on their site.
    Does anyone know of a fix for the rattle other than changing back to the stock cam or changing carbies?
    when the slide is closed can you rattle the slide in & out in the carb body  if you can the carb is worn a bit  it's been a city bike carb before? sit's around idling a lot that will wear factor , the slide hold's better in the body when it @ 1/4 +to full  opened, i know the early one's rattled easier but it would not realy matter what cam  it just means the engine is sucking a bit harder @ idle  stock cam have a latter lobe centre than the EV27 but i do not think thats too much worry ,   can you rebuild the slide
  • reaver_05
    reaver_05
    thks
    I'm gathering you can buy replacement slide for the carby?
  • wazdog
    wazdog
    Mine's done it since brand new out of the box with EV3 cam. Sometimes sounds like a fucked compensator. Get used to it.
