evo transmission
  • blueystar
    blueystar
     quick question on a 1997 evo 1340 5 speed transmission
    the nuts on the mainshaft/countershaft to remove is it
    ante clock or clock ways
    thanks bluey
    clockwise to undo lefthand thread your not on hear much  thesedays blueystar
  • blueystar
    blueystar
    Pop in every day just not post much these days
    Thanks for the info fitting a kicker to the road sweeper
  • jacko88
    jacko88
    Bluey, done this before mate so if ya get stuck get my number of Stevie and give me a ring
    Daz
  • blueystar
    blueystar
    Hello daz took the cover off and had a look
    That's as far as i have got
    What's the best time to ring
    Bluey
  • jacko88
    jacko88
    found the trapdoor tool bluey so if you can come down its yours to borrow mate and I will pick up as discussed the tool will pull the trapdoor off and install the new one evenly however you will still need to press new bearings into the new trapdoor I wouldnt bother with yours as they are not exy if you go to a bearing joint and avoid dealers. Most machine shops have a press so no biggy there either
  • blueystar
    blueystar
    thanks Daz will contact you when i can come down your way
    not much free time now that i am back in the work force after been layed up 18 months
  • blueystar
    blueystar
    DAZ found a trap door puller on ebay so ordered one as you said
    a handy tool to have in your tool box thanks very much for the offer
  • jacko88
    jacko88
    no worries mate
