Got some tools! Cam time.
  • Paulie73
    Paulie73
     Got me some tools for a cam change and collecting all I need. Is almost pushrods time and going easy install as motor is low ks and tight. Alloy or steel? That's the question .  So we got cam, bearing, gaskets , breather and shims as required? Just pushrods now.
     chromemoly steel only never use aluminium
  • the_mongrel
    the_mongrel
    I used the SnS Adjustable Rods. Steel from memory! Easy fit and seem to be going ok. :)
  • DK40
    DK40
    Used a set from FuelMoto on my last cam change.
    Really well made quality product and comes with an clip that holds the tubes up while you do the adjusting.
    You can reuse the stock tubes.
    About $ 139 from memory.
  • Ando
    Ando
    Maybe like I have
    i new you would have     but hes playing with a evo
    that was my point
    just getting my post count up
  • Paulie73
    Paulie73
     Cheers, I buy tools as I have a addiction. Always good to have and loan if needed. Thanks for the advise all.
