Tank change
  • 98superglide
    98superglide
     Gday guys,
    i was thinking of putting a diff tank on my 98 superglide. Anyone else done this? I would like to have the speedo on the tank, and I think the tank might have a bigger capacity? Any help would be appreciated. I believe 96-03 is the same frame? Any other tips would be appreciated.
    thanks,
  • Deadwood
    Deadwood
    Chopa, would an early 00 low rider tank fit the speedo and tacho from a FXDX do you know?
  • 98superglide
    98superglide
    Thanks guys,
    Chop, how hard is it to mod an efi tank to a carb? There are heaps that look good, no idea what's involved?
  • 98superglide
    98superglide
    Thanks mate, sounds like a bit to do....might cool my jets for a bit and do some research.cheers
  • 98superglide
    98superglide
    I havefound a great tank off a 95 wide glide. One guy tells me it will bolt right on, another bloke reckons it probably wont...does anyone know if a 95 tank will fit a 98 superglide?
    Thanks
