Online: wildchild, John.R
Shocks For a Dyna
  • Superglide2012
    Superglide2012
    Currently I have the stock shocks on my Superglide Custom Dyna.
    I hvae adjusted them a couple of times now for when the wife rides pillion but still they bottom occassionally.
    i looked at some on ebay but its rather confusing as some are saying they are 10inch and other 12 inch etc.
    What is a decent brand of shock etc to ttry to eliminate this problem.
    The wife is a stick but Im a fat bastard and it doesnt bottom out when I ride it by myself.
    I havent tried the maximum setting yet as I didnt want a hard ride but I may have to.
    Any help appreciated.
    I'll thank Tim SG in advance :) Always got good info that bloke!
    12" is stock length for FXDC 2012 . If you go for progressive , check out their website to get the correct code . They have a few different models starting with the412 series .Youtube clips from JC Motors explain the different models . I went for 430 series as the inner is chrome , cost me just over $400- delivered . When progressive say 250lb min weight for heavy duty springs they mean it ! I weigh 230lb and should have bought the standard spring . The standard rear shocks supplied on this model are shit .
  • Superglide2012
    Superglide2012
    thanks Tim. Hmmm2 that sounds good but I would like all chrome as the standards are chrome as is a lot of the bike. Im not sure black would suit then again they may be the go.
    Thanks again gentlemen.
  • Sparra
    Sparra
    Thanks mate...I just put a set of progressive's on my wideglide but put the heavy duty ones on and even on the lightest setting they are still a bit too form...I might try a set of these...
    Cheers...Sparra
  • Deadwood
    Deadwood
    Well the last shocks I had were 10.5in Burly's so the move up to these is like chalk & cheese. I don't think they're built for performance but they're damn comfortable and they keep the lowered look which I like. As a guide the bottom of the guard sits a couple of inches above top of the rim. I have mine set at 25psi for solo but I'm a bit bigger than hmmm.
    I have noticed some wallowing in the corners but I need to fine tune the air.
    Hope that helps.
  • Superglide2012
    Superglide2012
    Thanks Deadwood. I read the thousands of replies. :)
    That bike looks smick.
    Hmmm2 do you adjust your shocks at the servo or do you have a compressor at home?
    ANy chance of a photo of the shocks and the airlines?
  • Superglide2012
    Superglide2012
    Thanks mate.
  • Deadwood
    Deadwood
    Will look into it beags, thanks for the heads up mate. It was really a test run installing the touring shocks but I'm happy with the comfort they provide so I'll look into replacing the oil. Cheers
  • Superglide2012
    Superglide2012
    Thanks Baloffski
     Hey SG Hutch here. Lose some weight ya fat bastard! The end.
    P.S. ya missed a good ride last weekend. See ya next time.
  • Superglide2012
    Superglide2012
    It doesnt bottom out when Im on it by myself its when I put the wife on. That extra little amount causes the problem THOUGH your right I am a fat bastard. hahahahaha
  • beagle
    beagle
    Put some 13" shocks on and give it a bit more travel. The extra inch goes a long way ...LOL..
