Diseal in your petrol?
  • Crazy Erny
    Crazy Erny
    Pulled up at Kunungra the other day for a latte, (Yep, I know) & was parked next to a older bloke who owned some sort of Yamaha 1700cc I think, anyway we started talking bikes when I mentioned his pipes were running a bit rich. He replied it was the diseal he added to the fuel to keep the engine clean. When I questioned him somemore this is what he had to say. A while back he went to an automotive shop to buy some Micky Mouse (The Grouse) carbon, carby & injection cleaner, as he walked out of the shop he was reading the ingrediance of the product, & he notices that it was made from 98% petroulum by product, having been in the industry for years he nee it was diseal so he went back into the shop to querry this product. The salesman confirmened it was 98% deasil, & when asked what the other two % were, he was told, 1% was colouring & 1% scent. So he advised me to use about a small yogurt cup (140grams) to a full tank (18l) once a month, he reckons the plugs, valves, heads etc are clean as a whistle, & runs beautifully all the time! He also reckons he has used it for a few years!  Now in 50 years at this game this is the first time I have heard this & this is why I have posted to get some brain trust on this question. So what do you guys reckon?
  • Will67
    Will67
     try it in your car first or lawn mower.
    and its spelt diesel crazy
    Well i thought i'd better post. those two links you put up Willi are from USA diesel used to be a lot cheaper over there, so they are just trying to save $.
    but don't start putting Diesel into a petrol motor unless you are looking for trouble. in the old days before unlead fuel, all the pumps had the same pump nozzle diamiter & all the fuel taks had same large filler kneck. it was common to see people miss fuel & put diesel into a petrol tank then fuck there motor. same as because unblead has a small nozzle & diesel still has the old bigger nozzle, some people miss fuel diesels, but you have trouble getting a large diesel nozzle into a petrol tank filler kneck, so don't see diesel miss fueling in petrol now. if you use BP 98 Ultimate it will clean your injectors & clean up the chamber.  who wants a smoky bike?
    the best fuel aditive ever is Nitro!
    @ Crazy, a Road King perhaps?
  • chopa
    chopa
    Knew a bloke 30 odd yrs ago who had a VW and he would put a Gallon of diesel to a tank of fuel. He never had a problem with it
  • careyman
    careyman
    i`ve heard of people putting some metho in their fuel to get rid of moisture???
  • rider
    rider
    Would have thought that the black shit you noticed in his exhaust was a pretty good indication of what adding a lesser flash point and octane rated fuel was doing for the donk.
    De-rated fuel, de-rated engine performance ? The more diesel ya put in a petrol engine the worse it runs.
    Anyways, I'm not gunna change ta diesel,,,,,, I 'm more than happy with popping a few Viagara's in the tank every now and then !
  • aido
    aido
    I had an employee put unleaded into a diesel truck, now that doesnt work very well.
  • russ4570
    russ4570
    Where's the dead seal???
  • clubbie
    clubbie
    If you want an Octane bump just use toluene 10%. Stops pinging dead. Safe for carby and fuel injection.
    Toluene is also known as rocket fuel that was used in turbo F1 cars that made 1000hp from 1.5 litre engines and then banned.
    Nowadays toluene it is sold as octane booster (94%) or Solver paint thinner.
    If you want to clean injectors or valves add a small amount of trans fluid......... or pay 5x more for fuel injection cleaner.
    Clean moisture from tanks just add methylated spirts or a litre of E85 (ethanol/petrol mix).
  • adadrian
    adadrian
    My gramma always said that if u add a spoon full of vegemite to the tank every 3 months ur engine will never break down! She was right!!!
  • Maxiboy
    Maxiboy
    A low volume of diesel in fuel has been in common use. It's a great injector cleaner and has amazing lubricating properties. About 50-100ml per tank is all you need and not everytime either. Know several people that swear by it and have been doing it for years.
