• Superlow 11
    Superlow 11
     Just wondering what cams would work best ? I've got a 2011 super low with a Mach 2 air cleaner , rush mufflers and the S/E race tuner , all help would be great full .
  • Iron Eddie
    Iron Eddie
     Hey SuperLow, depends what you want the cams to do.  Why are you wanting them? That might help others make some suggestions for you to consider.  In the meantime check out this link it's for Hammer Performance and is a guide to cam options.  You may find though you end up considering other things as part of your upgrades.
    Hope that helps.  Good luck.
    IE
  • Superlow 11
    Superlow 11
     Thanks for the link iron Eddie ,I'd like to get a bit more mid to top end power if that helps
  • slapster
    slapster
    A good tune could help you out there Superlow. T1 can vouch for that.
    Beyond a tune I reckon bang for buck your best upgrade is a big bore kit. Cams will give you minimal gains, if any, where you're at now.
    Slap.
